So I have come around to consider working with electronics, in order to install led's into scale models. These would be 2-3V, 20mA lights and such, and afaik powered by some 9V power supply (I would have to rig that, which I've done before with 12V).
Now.. what a circus and horror show this seems, buying cheaper electronics equipment. My ambition to work with electronics would have to be to not ending up killing myself, and there is the appeal in acquiring an more affordable digital variable power supply and working with a multimeter.
I've already ordered the '
UNI-T UT61E' digital multimeter, and I think I will be happy with that. Seems safe enough for smaller things, but ofc I am fairly new to working with electronics and I am just used to wire basic lighting in my apartment (which is allowed legally where I live in Northern Europe). My mains are afaik AC 230V where I live.
What is more troublesome is buying the digital variable power supply. The only model that I am currently considering, is this older
KORAD KA3005P, and I like the design for the buttons compared to similar products which has a different front side set of buttons. I know there is a D version afaik without a USB port on the back, but I don't know if the P or D version would be better than the other.
Trawling through this forum thread:
https://www.eevblog.com/forum/blog/eevblog-315-korad-ka3005p-reviewfail/ I have the impression that I might perhaps get to have a decent power supply, but one that won't end up killing me because it was designed badly. Yet, the unit might fail, because it is a low priced product with questionable merit with regard to choice and the quality of components and design.
I guess I would like to know, what a customer ought to know in 2017, about this over five year old power supply, which I can buy off eBay and advertised as being "new". As seen here:
https://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=Korad+KA3005P&_sop=15Also, I am wondering if the KORAD KA3005P is suitable for working with small led's, that is designed to work with 2-3V and rated for about 20mA. The appeal, is to both toy around with the led's ramping up the brightness, test their longevity on a breadboard with some basic fixed 9V power supply), and generally try to get work with led's to have a working lighting setup on models should I decide to do all the work og rigging and designing a setup myself.
If you have anything to say about the choice of products here, feel free to chime in. I am curious to learn if there are better products for this price range of about $150 (USA dollars), and if the build quality is improved in 2017, as opposed to some years ago.
Also, perhaps most important, in a way. What dangers are there using such basic equipment as a digital variable power supply?
How can I safely open up the unit for inspecting the insides for obvious flaws? The only thing I know is that certain electrical components might have a hazardous/lethal current stored in them, even when the unit is not plugged to the regular power grid.
Presumably, it would be most important to check to see if the unit is properly grounded.
