I needed a way to test some SMD components on a breadbord. I came up with a solution that is so clean and easy to do that I now prefer to use SMD instead of thru hole on breadbord when possible.
I wrote a
tutorial with some (hopefully) helpfull hints, but the attached picture almost says it all. Since this tutorial got few views and people IRL seems to encounter this problem, I try to give it more visibility.
Do you know other interesting ways to use SMD on breadboard ?
John.
