Hello. I'm trying to build a simple transistor amplifier which I know usually suck, but it's just for the experience.
Anyhow, after figuring my amplifier doesn't work, I tried measuring the voltage that is coming from my computer audio jack which is enough to drive a pair of 32 ohm earphones, the ones you plug in your ear. However, the voltage I get is very low, about 20 mV at maximum volume. I'm generating a sine wave at 60 Hz and my multimeter is TRMS, so I believe that should work. On the internet people say the voltage should be about 0.4 V, or even 1 V maximum (2 V peak to peak).
Is my multimeter just bonkers or is this normal?
