Hey all.
in this tutorial
you are talking about Weller wsd solder irons to be a bad choise.
I have two, the w61 and the w101.
I do mostly car electrics and cabling soldering with them, never do sensitive stuff, i use my gas iron for this. (but maybe i have false fear to use them)
Is it okay to solder printboards like transmitters with this stuff?
I mean, to solder chips, cpu's ?
The iron is connected directly to the 230v mains, so maybe there is goiing current (ampere) or interference into the chip?
Or are these irons just as safe to youse like a base station with seperate iron?
I Always thought with a station there is only heat comming out of the tip, so no thinks that can damage sensitive components.
If this is indeed a problem i'm thinking to buy a Weller wd1000 station for sensitive stuff or are there better stations for around 300 Euro (370 dollar)
thanks. R-K.
