You measured the "sensor 1" in the pdf attached above (ntc/ptc)? There is also "sensor 2" which from the symbol looks like thermocouple.
I can check my wsp80 monday evening if no one other answers first.
And you tried the iron in the same port as the hotplate and it was not turned off? Quick read on the manual tells the channels can be forced off with button combinations.
Thanks! Yes, tried using the same port. (Actually, tried both, and hotplate was fine on both, and station did not acknowledge the iron on either)
I also found the "off" feature described (pressing up and down at the same time, nifty), however the station explicitly says "off" when it is off.
The "sensor 2" thing in the schematics is beyond me, but I finally figured out how to non-desctructively open the iron (prying loose the inner plastic washer), and the pins 1, 2, 3, 4, and 5 are connected on the iron. (The hot-plate has the same pin configuration, except it has no "ground" connection.)
If I got the schematics right, pins 1 and 2 is for the heater, and it measures fairly steady at around 6.9-7.0ohm.
Pins 3 and 4 is roughly 680kohm. Pin 5 is for ground or somesuch, and measures about 0.5ohm to the tip.
I tried hot-air-gunning the solder iron tip a little. Oddly, after a while the resistance started jumping back and forth in the 30ohm to the 160kohm range.
Plugging it into the station while it was still hot, the station frantically displayed anything between --- to 500 celsius, and anythng in between, so it seems a little broken.
I'm getting 22 ohm at room temp on mine as well.
Thanks! Yes, that's what I was afraid of.\\
I suppose it
could have been damaged in transport.
I'll fire off a message to the ebay-seller now. If I have to send it back, I fear the postage to china will be absolute horrors.
So much for being a cheap-ass!
Geir
