I'm a bit new to this so I suspect I'm doing something wrong and I'd appreciate any pointers.
I took delivery today of a Siglent SDG1020 to replace the cheap eBay special I already have. The problem is, it isn't behaving as I would expect.
I've set a 30Hz square wave at 50% with 4vpp ( just playing about, the values aren't significant ) and my scope is telling me the signal is +7.4vpp with an offset -3.84v.
Thinking the problem may be with the cheap scope*, I plug in the old generator with the same settings and I get on the scope what I expect! 30Hz, 4vpp, 0v min, 4v max, 50% duty.
I've tried the 'Self Adjust' menu item with no difference and channel 2 produces a similar effect - although I can't set 4vpp on channel 2 ( SDG1020 limitation ).
I naturally think that it's me doing something wrong but when I see a 4vpp setting and the scope is saying 7.4vpp there is an element of doubt that the SDG1020 is working properly.
Help please! And apologies in advance if it's me being stupid.
* and yes I've seen Dave's video about it and I know his opinion! A new one will be purchased in the new year
