Also, when I do end up using Multisim, I get super annoyed that you can't even simulate an inductor with real-world characteristics without adding them as discrete components. And a lot of things do not work as expected if you simulate them with ideal components vs real-world ones!
Well, there are some ferrite bead components in there, which still are only modeled as R + RLC circuits (roughly correct, but not very accurate at any particular frequency).
FYI, note that models returned from e.g. KEMET Spice are the exact same thing: a lumped equivalent model valid only at one frequency, and only grossly similar at others.
I don't know of any other packages or libraries with accurate inductor data (if such things exist, I would be interested!). If you mean in comparison to LTSpice allowing the arbitrary specification of parasitics (which I don't like*), that can be abused in all sorts of ways that aren't at all apparent from the schematic. And anyway, with a little SPICE code, you can build the same thing in Multisim -- a .SUBCKT with PARAMs is one thing, but they can be one step even more convenient with active / dialog controls (take the non-ideal transformer component, for instance).
*They're hidden away in a dialog box, so unless you take the time to download the .ASC and inspect every line, you don't have a clue if any of the R, L, C or V/I sources are anywhere near what they claim to be. For simulation purposes, I would much rather see the explicit components, or at least an "arbitrary impedance box" with the parameters labeled on the schematic.
As for actually really accurate inductor models, they're not easy to make, and that's given actual data and specifications from the manufacturer. Take this example,
http://seventransistorlabs.com/Images/CurveFit1.pnghttp://seventransistorlabs.com/Images/CurveFit2.pngThe impedance isn't a constant inductance, it kinks to about f^0.5, probably a "skin effect" effect. The rolloff corresponds to winding capacitance, but the resonances could be better modeled, if it were necessary that is. And this is just common mode; who knows what differential or normal modes look like.
Easily 95% of all inductors have no published data whatsoever (beyond DCR / temp rise, and Isat if applicable), making the whole procedure orders of magnitude more expensive (test equipment required, etc.).
