I'm wondering what is causing glitches in the output waveform when I run a sine wave from my function generator through a transformer.
In the attached pics note the major glitch at the crests of the output and also the smaller ones to the left and right.
This is with a 2 KHz sine wave input. As I increase the frequency the major glitch at the top goes away, but the one of the left is still perceptible up until about 70 KHz (under x10 magnification). The location of the glitch also seems to shift with frequency moving to the left as the frequency increases.
The transformer looks like one you'd find in a PC power supply, ie. something like this:
The function generation is a FY3224. I've connected it to one winding and I'm probing another winding with the scope.
