3.3.2. Floating operation. In many memristor emulators,input and output signals are given with voltages from theground. To use a memristor emulator in wide applicationareas, it needs to have a floating operation. This floatingfeature is achieved with the current conveyor, denoted asCC0. With the architecture in figure 3, input voltage can beapplied between the V+ and V? terminals, which is thefloating operation.
It simply means that the input voltage does not need to be referenced to ground in this case. Two input terminals are provided (V- and V?, is that a typo?), and only the difference in potential between the terminals is important.
3.3.3. Connectability to other devices. To be a part of acircuit, the memristor emulator has to be connectable to otherdevices. To have connectability, the same current as the inputcurrent must appear at the output terminal of the memristoremulator, and the voltage at the input terminal of thememristor emulator should be the sum of the memristoremulator’s voltage and the voltage of the other device. Theformer feature is realized with the current conveyor, CC0,where resistances RC and RT are set to be equal. By applyingthe same voltage as that of RT at the y terminal of the currentconveyor, the same current as the input current, iin, flows fromthe x terminal and at the output (terminal z). This feature isbuilt with the analog voltage adder, U5, and a buffer, U4.
