Author Topic: What does the star mean in a schematic  (Read 4920 times)
Offline HappyBananaTopic starter
« on: July 23, 2016, 08:21:00 pm »
Hello,
excuse me if this is a stupid question, but google isn't turning up any helpful results. What does a * mean in a pin number on a schematic? I am looking over a ATSAMD21 board from adafruit (https://cdn-learn.adafruit.com/assets/assets/000/028/801/original/adafruit_products_M0SCHEM.png?1448656357) and both pins 18 and 17 have a star next to them and another number. What is the meaning of this?
Thanks,
Tyler
Offline Monkeh
Re: What does the star mean in a schematic
« Reply #1 on: July 23, 2016, 08:23:01 pm »
This is specific to Eagle. It indicates multiple physical pins or pads are assigned to that pin on the schematic. Most tools won't do this (which is depressing when you have six or more pairs of power and ground pins).
« Reply #2 on: July 23, 2016, 08:32:00 pm »
Must you connect all the pins then? For example pin 18, 35, and 42 are all ground pins. Would I be fine if I only connected pin 35 to GND? I would think they would be connected internally.
Offline Kilrah
« Reply #3 on: July 23, 2016, 08:34:20 pm »
They may or may not, the chip's datasheet would tell you about that. If in doubt better to connect them all.
Offline Signal32
« Reply #4 on: July 23, 2016, 08:35:52 pm »
What does this mean exactly?
On the schematic you can see 17*2 goes to 3V3. Then on the right 2 goes to the XTAL.
Offline Monkeh
« Reply #5 on: July 23, 2016, 08:37:41 pm »
Yes, you must connect them all.
Not pin 2, 2 pins.
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #6 on: July 23, 2016, 11:07:03 pm »
thats what it means... some chips have 4 pins or more for GND on all of its edges....
Online bitwelder
« Reply #7 on: July 24, 2016, 06:44:16 am »
Here is the datasheet for SAM D 21, and at paragraph 5.2.1 (page 26) there is the pinout for the SAM D21 G in QFN (as used by Adafruit): http://www.atmel.com/Images/Atmel-42181-SAM-D21_Datasheet.pdf
There are indeed 2 pins on VDDIO (17 and 36), but only 3 are designated as GND (18, 35, 42). Where's the supposed fourth one? (GNDANA at pin 5 is reported separately in the schematic)
Offline Monkeh
« Reply #8 on: July 24, 2016, 12:00:15 pm »
It's a QFN. There's a massive pad on the bottom.
The following users thanked this post: bitwelder
