Difficult to say, you have to deduct this yourself.
Look at which pins are Vcc and which are GND.
Then probably it is an SPI or I2C eprom so first try to find that out (measuring protocol or deducting from other connected chips on the bus)
Than you can try to guess which it is and try it or first try to read out the memory with your own microcontroller so you know which size (2kB, 4kB, etc) it is to make a better guess.
As long as you know 100% which is Vcc, Gnd and if it is SPI or I2C and you respect the pinout there is not much you can do wrong.
