I am sure you will be very satisfied.
HM650 is an excellent analog osciloscope, perhaps one of the best manufactured by HAMEG.
They are not as reliable as Tektronix or an HP one, but they are easy to repair with readily available components.
If you have some trouble, look first for bad solders and interrupted diode in bridge rectifier of the power supply.
The component tester is very useful for troubleshooting and once you have learned to use it well, you can not live without it.
There is no true dual time base, it has only a variable delay.
It is not as good because of higher jitter, but it is usable.
It is very easy to use and syncronization is particularly good.
Buy a counter and connect it to the BNC output of the vertical amplifier available at the rear of the unit for accurate reading of the frequency.
Enjoy.
