For low leakage, fairly large capacitors, there's no need for a nano-amp meter.
Charge the capacitor up to its maximum voltage.
Leave it, with nothing connected to its terminals, for a known period of time.
Measure the voltage, as quickly as possible, preferably with a meter which will take the maximum reading and hold. The input impedance of a 10M meter can be boosted by adding high value resistors in series with it and the actual voltage can be calculated, using the potential divider formula.
Calculate the charge lost and thus the RC time constant and the leakage current.
