Resistors rarely fail short, almost always they go smoky and open circuit, unless you have a wirewound one with no core ( heater element) which goes short circuit before it blows open. That is a ferrite bead on a wire, it does a pretty good imitation of a wire at DC, and appears as a very lossy resistor at RF. the set shutting down with time means more faulty caps, likely on the inverter board or the main board along with the power supply. Bulging is not always an indication, you need to measure ESR and decide, or if they are made by Mr OHLo then replace on sight. If Lelon definitely so.
