Author Topic: What is resonant impedance?  (Read 1335 times)
Offline chipwitchTopic starter
  • I barely know you!
« on: March 27, 2014, 03:55:51 pm »
I bought some of these generic piezo elements on ebay.  http://www.ebay.com/itm/121270884189?var=420233429010&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
The specs at the bottom indicate "Resonant Impedance" at 200W?  Google is showing a bunch of hits that I don't think is the same thing.  The "watt" units was throwing me.  I would think it should be Ohms?
hello?.... <screech>.... is this thing on?
Offline Dago
    • Electronics blog about whatever I happen to build!
Re: What is resonant impedance?
« Reply #1 on: March 27, 2014, 04:25:49 pm »
The omega symbol '?' often gets converted to 'W' due to re-encoding characters to a different encoding.
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
Online IanB
« Reply #2 on: March 27, 2014, 04:51:36 pm »
The lower case Greek letter omega looks like a curly "w". Since the ohms symbol is an upper case omega, it sometimes happens that uppercase "W" is used to represent uppercase "Omega":
It's a bit odd, since omega is really a letter "o", not a letter "w". But using uppercase "O" would lead to confusion with zero, so "W" is used to avoid that.
« Last Edit: March 27, 2014, 04:53:42 pm by IanB »
« Reply #3 on: March 27, 2014, 05:46:51 pm »
Ah... yes.. now it makes perfect sense.  Thank you.
