Ahhh yea now things are starting to make sense to me,,, yea now that you mention it I was having problems with one of the batts ( hence why it is in the garage) ok kewl it is all kinda makin sense to me,, soo I guess my question would then be ,,, would just measuring and recording the voltage (seems to be less expensive overheadwise) with an arduino and just forgetting about the amperage unless there is a prob or somethin going to be a sufficient judge of the system performance,,, I am most likely going to be watchin the voltage with the arduino to fine tune the 2 axis tracker to max out so I can just use that ref for efficiency reports (holy smokes did I just spell that rite )
tks poot36 also reminding me its a 24v system and need to run em in par 2 get anything. I have a couple of 50ah slas from another chair that I was planning on using 4 an elec tractor,, so might as well charge em up see what I can get out of em.. I am thinking off the top of my head if I am seeing one amp and I usually charge at 10 or so on my charger then I should get a pretty good couple of ahs after a couple of days,, gimme sometin 2 play with at the least,, and 100ah is a pretty good bit of time to be runnin just some water pumps and what not to move hot water around and heat things up.
Thanks again 4 the replies super appreciated (I am sure Dave does 2 so I won't bug him with this simple stuff lol)
~Tim ;~)
