I've never ever owned an ESR meter or an LCR meter because the cheap ones are usually too flawed in their operation for me to want to have one. But they can be useful faultfinding tools for some users.
However, low cost H/H ESR meters do seem to be getting better recently and the DE-5000 does look to be a decent instrument.
I currently use a crude in circuit test setup using a sense resistor and some other test gear when doing initial faultfinding and this crudely looks for faulty Hi Z caps. But if I want to measure a cap reasonably reliably for capacitance and ESR then I will remove it and use a pure sinewave source, a known sense resistor and a decent DMM or scope. Then put the measurements into a calculator and calculate the capacitance and ESR using classic impedance equations. It's a slow method but miles better than the traditional cheap old school ESR meters in terms of reliability of measurement and I know I'm measuring the cap at a known frequency and I can also feed in an external DC bias to the cap at the same time when testing it.
Few people will have the patience to use the slow (classic) manual method I use so If someone was going to buy an ESR meter then the DE-5000 looks to be far and away the best budget buy if you want something decent
