Author Topic: What is the max voltage rating of a typical 1/4W E24 resistor?  (Read 4903 times)
Offline dog80Topic starter
« on: December 18, 2013, 01:03:24 pm »
I want to use a resistor for a very tiny current at mains voltage. The power doesn't exceed 0,25 Watts, but are these mains rated?
What is the max voltage rating?
Online mikeselectricstuff
    • Mike's Electric Stuff
Re: What is the max voltage rating of a typical 1/4W E24 resistor?
« Reply #1 on: December 18, 2013, 01:18:32 pm »
Take a look at a few datasheets - ISTR around 200V is typical. For mains I'd suggest using 2 or 3 in series to spread it out. Bear in mind you may have transients,
Day Job: Mostly LEDs
Offline Neilm
« Reply #2 on: December 18, 2013, 04:58:24 pm »
Also bear in mind that resistors can (and do) fail short circuit. I would go for 3.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline qno
« Reply #3 on: December 18, 2013, 06:21:13 pm »
There are special Hi voltage resistors.
Jus take a look at Farnell or RS and search for resistors with a 500 or 1000V spec.
Why spend money I don't have on things I don't need to impress people I don't like?
Offline olsenn
« Reply #4 on: December 18, 2013, 08:05:56 pm »
You can also get transient voltage supressors if you're worried about transients. A decent quality HV resistor should be perfectly fine for 220V though
