Vceo is the maximum Voltage the transistor can withstand on its collector measured relative to its emitter with the base open circuit.
Likewise:
Vcbo is the maximum
base with the emitter
open circuit.
Vbeo is the maximum
base measured relative to its
emitter with the collector
open circuit.
How can I calculate the V__o? Thank you.
As
Ian.M has said - you don't calculate these. The manufacturer designs and tests the device to
provide you with the information via datasheets. They GIVE you these numbers (and a whole lot more) for you to use in designing your own circuits.
