Hi All, I’ve been cannibalising some old pcb’s and came across what I thought were four neons on a board with a couple of small coils and a variable resistor. On closer inspection I saw there are two filaments which join at a small, central bead. I then thought they might be some form of thermistor like the old RA53, used as a stabiliser in oscillator circuits, but I can’t find anything with four terminals like these. Despite the filaments being connected, the resistance between the two green leads is 180 ohms and 8 ohms between the red and black leads. There is no diode action between any pair and there is open circuit between red-green and black green. I’ve never seen bulbs that look like this, so any ideas as to what they are?
Cheers.
