Author Topic: Delete Delete Delete  (Read 2652 times)
Offline The_Almighty_Bacon_LordTopic starter
« on: July 11, 2016, 08:29:17 pm »
« Last Edit: August 16, 2020, 06:59:33 pm by The_Almighty_Bacon_Lord »
Offline bktemp
Re: What is this?
« Reply #1 on: July 11, 2016, 08:34:49 pm »
It is a capacitor. It has the modified package type for reduced parasitic inductance (larger solder connection, smaller distance between pads).
Offline PA0PBZ
Re: What is this?
« Reply #2 on: July 11, 2016, 08:36:09 pm »
I *think* it is a capacitor, and it looks like it is designed to have a low esr, that is why it looks turned 900.
But I have no experience with this so I could be totally wrong  ;)
Online ataradov
    • Personal site
Re: What is this?
« Reply #3 on: July 11, 2016, 08:38:57 pm »
They are indeed low ESR capacitors.
Alex
Offline PA0PBZ
Re: What is this?
« Reply #4 on: July 11, 2016, 08:45:19 pm »
Would all the capacitors which look similar to it be the same/similar nano-farad rating? Would it matter if I pulled any of the same-sized capacitors from the CPU with more caps missing, and move it to the CPU with only 1 cap missing?
Yeah, that would be the thing to do.
Online ataradov
    • Personal site
Re: What is this?
« Reply #5 on: July 11, 2016, 08:45:52 pm »
Not at all.
Do that, those are mostly bypass caps they don't really matter.
Alex
Online ataradov
    • Personal site
Re: What is this?
« Reply #6 on: July 11, 2016, 09:33:03 pm »
Next thing... How do I remove flux that has turned dark brown? It's over some of the gold pads near that capacitor.
With alcohol.
I'm afraid of accidentally removing some gold pads.
Don't use excessive force.  Those pads are not that easy to remove even if you wanted to. You are not gona damage them by gently rubbing them with alcohol.
Alex
Online ataradov
    • Personal site
Re: What is this?
« Reply #7 on: July 11, 2016, 09:40:05 pm »
Are you sure that isopropyl alcohol (99%) will remove it?
Of course it will, otherwise entire electronics industry would have really tough time getting anything done :)
Alex
Online ataradov
    • Personal site
Re: What is this?
« Reply #8 on: July 11, 2016, 09:48:07 pm »
Watch your language.
It would have turned on even without that cap.
Alex
Online ataradov
    • Personal site
Re: What is this?
« Reply #9 on: July 11, 2016, 09:54:08 pm »
So it's actually less impressive then I think it is?
I don't know how impressive it is. Those capacitors are providing local power bypass. If you have reasonably designed motherboard, then things will work (or at least try to boot) if you remove most or even all of them. They mostly affect system stability under varying load.
Alex
