Author Topic: What is this black blob on PCB?  (Read 22378 times)
Offline Fishplate42Topic starter
  • Applying electronics to my other interests...
    • Ralph & Sue's Meccano
« on: May 23, 2012, 04:08:11 pm »
OK it is dumb question time...
I have just taken apart a cheap USB hub (for the sockets and lead) and I now have the PCB left with a few SMDs and an LED bit what is the black blob of epoxy-looking stuff for? As you can see I have had a go at getting it off but it is stuck like you-know-what...
Here is a picture of the blob!
Thanks!
Ralph.
Electricity is smoke. I know this because if you let it escape the darn thing stops working ;)
Offline Bored@Work
Re: What is this black blob on PCB?
« Reply #1 on: May 23, 2012, 04:22:14 pm »
Below is the IC that performs the hub's function.
Online Monkeh
« Reply #2 on: May 23, 2012, 04:24:29 pm »
Big old lump of epoxy to stop the evil people who'll copy their reference implementation of a board for a bog standard chip which requires virtually no external components. Because clearly that saves them lots of money to cover the cost of the epoxy.
« Reply #3 on: May 23, 2012, 04:36:18 pm »
Ah! That makes scene - thank you! Is there any way of telling what the IC is? or is it just educated guess time. Would I be right in thinking it must be some kind of amplifier?
I also have a - don't laugh - a plastic frog that came from the same pound shop and that has a sensor in its mouth plus a little PCB with a similar 'blob' on it there is a picture on my blog http://ralphsworkshop.blogspot.co.uk/ . When the frog detects movement  it crokes three times and stops. The blob is covering the IC controlling the 'croke' so what might that be? or is there no way of knowing.
Thanks again,
Ralph.
Offline T4P
  • Country: sg
    • T4P
« Reply #4 on: May 23, 2012, 04:39:03 pm »
It might be a bare silicon chip just epoxied to save costs, seen on many cheapo autoranging meters
Offline Bored@Work
« Reply #5 on: May 23, 2012, 05:01:36 pm »
Not easily in this condition. One could try a guess from the PCB layout. Or experts could resolve the blob and check the bare chip under a microscope.
The easiest way would have been while the hub still worked. A USB hub, like all USB devices, can be asked for certain details, and this can sometimes reveal the chip, especially for no-name products.
No, USB hubs are not simple amplifiers. You could think of the chip more as a very specialized processor for processing USB data. If you want to learn what a hub must be capable of doing, then you could check the USB specification (lots of paper).
Some specialized sound chip, maybe similar or even identical to those one can find in electronic greeting cards. Chinese manufacturers are very creative when it comes to use those chips. For example, there were flickering electric candles on the market. Some clever soul figured the flickering was not really random. When reverse engineering the candle people found out the manufacturer used a greeting card chip. Instead of having the chip driving a speaker it drove the candle's light, resulting in rhythmic flickering.
The technique of using such a naked chip protect by a blob is called Chip on Board (CoB). CoB is not really used to protect design from reverse engineering, but because it is cheap if you produce very high volumes.
« Last Edit: May 23, 2012, 05:03:32 pm by Bored@Work »
Offline armandas
  • Country: jp
    • My projects
« Reply #6 on: May 23, 2012, 08:39:54 pm »
If you're lucky and didn't get a fake hub, that is.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #7 on: May 23, 2012, 11:35:26 pm »
continuity testing might help?
The Ultimatum of False Logic... http://www.soasystem.com/false_logic.jpg
Offline codeboy2k
« Reply #8 on: May 24, 2012, 02:11:04 am »
seems legit.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #9 on: May 24, 2012, 03:37:09 am »
Just to have an idea on what is involved on a USB HUB, check the datasheet of a "stock" device:
http://www.ti.com/product/tusb2046b
This is known as "die on board" - an IC that is cut from the silicon wafer and glued to the board. If I am not mistaken its boom started with the japanese digital watches of the 80's. It saves board space and a lot of money due to packaging.
The link below has some drawings that give a better idea:
http://www.google.com/patents/US5959247
Offline amyk
« Reply #10 on: May 24, 2012, 10:33:18 am »
Wow. At first when I read "didn't have any chip inside, only tracks" that wouldn't be a sign of anything wrong, since the actual die is tiny and would probably come off along with the bond wires, leaving only the pads behind. But the way the silkscreen contradicts the actual arrangement and soldering would've been my first sign of something suspicious, and the way the crystal is connected would never work.
Even if there was a real die and everything in there, the track layout wouldn't make for any reliable communication at USB 2.0 speeds. There might've been a 1.1 hub with a similar design that they copied for making this "USB splitter".
Here's a (despite the caption) real hub that's missing all components except the sockets:
http://www.flickr.com/photos/drug123/5127906425/#
Notice the pads for the bond wires are there.
« Last Edit: May 24, 2012, 10:38:09 am by amyk »
Offline CyberWalker
  • Country: gr
  • Courage doesn't always roar.
« Reply #11 on: May 24, 2012, 10:39:01 am »
I've tried (on dead circuits) to see what is afterall under all these epoxies... and yes, most of the times they are just bare ICs!
I've been messing with hardware ever since I can remember myself... I always loved hacking the science out of stuff but it was not until the age of 14 that I could proudly present something useful out of it! ;-)
I love technology and anything that includes a sophisticated concept or design! :-)
Offline T4P
  • Country: sg
    • T4P
« Reply #12 on: May 24, 2012, 10:40:51 am »
Wow ... just wow  :o
« Reply #13 on: May 27, 2012, 04:05:50 pm »
I now understand what the blob is and I am now experimenting with these pound-shop novelties. I know this may seem a bit trivial but it does give me something to experiment with and not spend a fortune. I have already learnt a lot from this post alone.
Thanks for all your help - this really is a great place!
Ralph.
Offline Codemonkey
« Reply #14 on: May 28, 2012, 08:42:48 am »
For what its worth, its a chip packaging method known as "Glob Top".
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
« Reply #15 on: May 31, 2012, 11:10:13 am »
Glob Top or Chip on Board (COB) packaging.
Mass producing stuff on small PCBs like that, the marginal cost savings add up to quite a large amount. Rather than wirebonding the IC die to a plastic pin package, which is then soldered to the board, the die is wirebonded directly to the PCB and covered in epoxy for mechanical strength etc.
See the second page of this: http://www.fkdelvotec.at/files/press/COB_E2.pdf
It's quite common in mass produced cheap products. Pretty much every character LCD i've seen has the lcd driver chips as a COB.
