I have a simple unregulated power supply, with a Schaffner FN9222R-1-06 Mains Filter going into a Myrra Transformer 45065, 2x115V primary, 2x18V secondary, 30VA. The secondary coils have a full rectifier and smoothing caps of 4700uF. It is set up as a split supply with +/- 18V output. With a 0.5 load applied between +18 and 0, or 0 and -18, in addition to the usual ripple I get a high frequency signal as shown in the attached scope shots. Can anyone tell me what the source of this noise is? It's about 1V pp which seems quite large. Is there any easy way to get rid of it? This output will be the source for a more regulated supply, so would it be worth putting a low pass filter on the output to reduce it now, or catch it again further down the line?
