You probably want a linear taper pot, not a log taper pot. The log pot will spend the majority of its rotation at either very close to zero speed or full speed depending on which way you wire it. Their example shows a 10k pot so clearly that will work fine. 47k will probably work but will be a bit non linear given the ~100k input impedance listed.
