Author Topic: What kind of prototype board is this?  (Read 4640 times)
Offline LegionTopic starter
« on: July 20, 2014, 06:32:31 am »
I can't remember what this type of board is called. I think you need some kind of special tool to remove the connections between holes, kinda like a punch. Anyone know the name of this type of board and what that tool is?
Offline miguelvp
Re: What kind of prototype board is this?
« Reply #1 on: July 20, 2014, 06:38:11 am »
perfboard
http://en.wikipedia.org/wiki/Perfboard
Edit: with ground plane that is
« Last Edit: July 20, 2014, 06:40:35 am by miguelvp »
Offline miguelvp
« Reply #2 on: July 20, 2014, 06:50:57 am »
Sparkfun calls it a protoboard but on the description they mention it's a perf board as well:
https://www.sparkfun.com/products/8815
NOt like any perfboard I used, then again I usually use stripboards for prototypes.
Offline Richard Crowley
  • KJ7YLK
« Reply #3 on: July 20, 2014, 07:02:53 am »
"Perfboard"
There are similar boards called: "Vector-board" (with no pads)  or "Vero-board" (with rows of pads connected together.)
WHAT "connections between holes"?  I don't see any connections between holes.
I see an ordinary "pad-per-hole" board with ground-plane on one side, and square pads on the reverse.
Vero-board requires a special cutter to isolate individual holes/pads. But that is not necessary for your board.
« Last Edit: July 20, 2014, 07:06:06 am by Richard Crowley »
Offline jancumps
  • New Low
« Reply #4 on: July 20, 2014, 07:11:26 am »
There was a screwdriver-like tool to break the copper traces for veriboards.
You'd put the tool in a hole and turn it clockwise. That would rip a piece of the trace.
Offline nanofrog
« Reply #5 on: July 20, 2014, 08:19:17 am »
Spot Face Cutter is the name I recall, and what Vero seems to call it as well (they sell a drill bit molded into a plastic handle for ~10GBP |O).
Farnell sells one from Duratool (they call it a track cutter). Business end looks more like a proper bayonet spot face cutter, has a nicer handle IMHO, and is less expensive.
Offline jancumps
  • New Low
« Reply #6 on: July 20, 2014, 08:24:19 am »
It's that Duratool model that I was refering to.
Offline rob77
  • Country: sk
« Reply #7 on: July 20, 2014, 10:37:42 am »
i'm using vero-boards a lot - but not using any special tool for cutting the traces. proxxon micromot (similar to dremel) with 0.8mm diamond tip does the job quite well, and i can cut at any place - not only around the hole. i can even cut between 2 adjacent holes and have enough copper left to solder leads to both holes.
« Reply #8 on: July 20, 2014, 12:20:48 pm »
I use a combination of a 5mm drill bit used hand held and a sharp blade, depending if i want to cut in a hole or between them.
Offline rob77
  • Country: sk
« Reply #9 on: July 20, 2014, 12:24:52 pm »
tried the drill bit - a sharp  5.5mm one - used by bare hand. actually it's faster than anything else  if a cut at the hole is needed  :-+
« Reply #10 on: July 20, 2014, 02:44:31 pm »
Veroboard and spot face tool. Thanks! I thought that's what this is since I don't see how you could solder anything onto here without it connecting to everything else. But maybe my soldering skills aren't precise enough.
  • KJ7YLK
« Reply #11 on: July 20, 2014, 04:36:22 pm »
NO, That is NOT Veroboard!  The board in that photo shows single pad-per-hole perfboard.  No tool is necessary to separate the pads, because the pads are already separate!
Start practicing your soldering skills, then.  Be sure to have a nice, hot, thin tip, and fine rosin-core solder.  DO NOT attempt to use "lead-free" solder as that is challenging even for people with decades of experience.
« Reply #12 on: July 20, 2014, 06:15:10 pm »
I didn't phrase that well. What I meant was veroboard and spot face tool were the items I had in mind. Not to say that this particular board is veroboard.
As for the soldering, I don't enjoy messing around with tiny, finicky things, so I'll just toss these. I like my electronics more "Duplo" and less "Lego". If it has to be small I'd rather just have it manufactured.
