Author Topic: What kind of stepper motor driver?  (Read 2856 times)
Offline EoiserTopic starter
« on: February 19, 2014, 01:05:29 pm »
Im going to buy a stepper motor for a project i have in mind.
Its a bipolar stepper motor
Im thinking about this one .
TRINAMIC - QSH4218-51-10-049 - STEPPER MOTOR, 1.8DEG, 1A, 0.49NM
http://no.farnell.com/trinamic/qsh4218-51-10-049/stepper-motor-1-8deg-1a-0-49nm/dp/1010727
What driver should i buy with this one?
Offline edmundopt
  • Country: pt
  • There's theory and practice...
Re: What kind of stepper motor driver?
« Reply #1 on: February 19, 2014, 04:50:04 pm »
You mentioned BUY, not build one right ?
You live at Norway, so I can't sugest my usual supplyer.
but anyway, what are you going to connect the driver to? (microcontroler, breakoutboard,industrial)
What will be the power supply voltage? (12/24/48)
« Reply #2 on: February 19, 2014, 05:42:38 pm »
Which ever one works..
What are you going to connect the driver to? (microcontroler, breakoutboard,industrial)
Microcontroller, AVR to be exact
12V
Offline edmundopt
  • Country: pt
« Reply #3 on: February 19, 2014, 07:09:09 pm »
If you want a quick solution, for 1A, you can go for the really old L298 IC.
If you want to learn a lot more, make yourself a dual MOSFET H Bridge with some sensing circuit.
You have the excellent Microchip AN906.
If you want to go really into stepper motor drives, check Microchip AN1307.
there are other ways, you have to choose if you want to buy it and have it running tomorrow or if you want to learn and have it ready, next month, maybe :)
« Reply #4 on: February 19, 2014, 09:37:46 pm »
This is purely for educational purposes, so time is not a factor.
I just want to learn as much as possible, and have a decent functional system.
« Reply #5 on: February 19, 2014, 09:54:06 pm »
I see that the Duet board for the RepRap 3d printers use an A4982 Stepper driver
« Reply #6 on: February 21, 2014, 11:46:27 am »
bump
Offline jaxbird
« Reply #7 on: February 21, 2014, 11:55:21 am »
Something based on DRV8811 or DRV8825 should work nicely with this motor.
Or make your own circuit, just follow the directions in datasheet:
http://www.ti.com/lit/ds/symlink/drv8811.pdf
http://www.ti.com/lit/ds/symlink/drv8825.pdf
Analog Discovery Projects: http://www.thestuffmade.com
Youtube random project videos: https://www.youtube.com/user/TheStuffMade
