Author Topic: What Soldering Temp. Do You Use For Lead Based Solder?  (Read 18545 times)
Offline RCPilot1234Topic starter
« on: September 15, 2014, 01:27:22 am »
Hey everyone,
I'm wondering what temperature you guys are using for standard RadioShack 60/40 lead based rosin core solder? I'm mainly soldering relatively small components for RC planes, multi rotors, etc. I know that 330 celsius is meant to be too high, so I want to lower the temperature but I'm just not sure by how much?
Kind regards,
Francis :)
Offline liquibyte
Re: What Soldering Temp. Do You Use For Lead Based Solder?
« Reply #1 on: September 15, 2014, 01:34:47 am »
From Wikipedia, 60/40: melts between 183–190 °C (361–374 °F).
« Reply #2 on: September 15, 2014, 01:49:56 am »
Thanks for your really quick reply! :) I read up on that before I posted, but wondering what threshold there is? Would you recommend around 220 celsius, or is there no point going much above the melting temperature?
Kind regards,
Francis :)
Offline Fsck
  • sleep deprived
« Reply #3 on: September 15, 2014, 01:56:12 am »
I'd try 525F if you're really worried. if your iron is barely above melting point, it'll take (relatively speaking) forever to heat anything up to that temperature.
"This is a one line proof...if we start sufficiently far to the left."
Offline liquibyte
« Reply #4 on: September 15, 2014, 02:03:45 am »
I keep mine around 300C to be honest but I think this is a personal preference and probably has been discussed quite a bit on here.  I seem to remember a recent thread along these lines.  I prefer a higher temp to "get in and get out" as it were, but I did learn on a fire stick and can solder really well with one too.  Too low of a temp and I tend to dwell too long.
Offline dfmischler
« Reply #5 on: September 15, 2014, 02:21:33 am »
IIRC the US NASA and MIL standards said the iron was to be set to 600 degrees F (315C).  That is high enough to get the work done efficiently, if you have good equipment, without causing loads of problems with too much heat.  I frequently set the iron to 350C for my own use.
Offline Whales
    • Halestrom
« Reply #6 on: September 15, 2014, 02:23:11 am »
How hot you solder depends on a few things, not just solder melting point.:
  • How nice your iron is.  Thermal conduction is not perfect, and the temp sensor may be placed far back
  • How much thermal mass you are soldering
The drop of temperature between sensor and actual item necessitates us to use temperatures greater than the melting point.  If you are patient, solder small items and/or have a nice iron then lower temperatures will feel fine.
From what I have seen most people solder between 280 and 350.  I leave my iron at 350 because it's a particularly bad one.
Offline nanofrog
« Reply #7 on: September 15, 2014, 03:36:50 am »
FWIW, I primarily run at 600F/315C for lead based.
Offline David Hess
  • DavidH
« Reply #8 on: September 15, 2014, 03:37:24 am »
I use Weller Magnastat irons with a 700F tip when doing assembly and general work and 600F tip when doing rework on boards where I want to be cautious about lifting traces.
Online IanB
« Reply #9 on: September 15, 2014, 04:02:52 am »
You can adjust the temperature by the behavior of the iron. Adjusting the temperature by observation will be more useful than going blindly by some number.
The temperature should be set high enough so that the solder flows rapidly in the joint and you can complete each joint within 3-5 seconds. If this is not possible, increase the temperature.
The temperature should be set low enough so that the solder on the tip of the iron maintains a metallic, clean appearance. If the solder on the tip rapidly forms a white, dirty, crusty appearance the iron is too hot.
When soldering the flux should melt and bubble and produce just a slight wisp of smoke and should remain liquid until the joint is complete. If the flux spits and hisses, produces large volumes of fumes, or dries out before you can finish soldering the iron is too hot.
FYI, I generally set the temperature of my Hakko to 650 F (340 C) according to the above guidelines.
« Last Edit: September 15, 2014, 04:05:16 am by IanB »
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #10 on: September 15, 2014, 04:07:00 am »
I use a Hakko FX-888 at 350C.  People often use more (370-400C), but I don't like this as the tip (among other things) burns too readily.  For fine work, a lower temperature is acceptable (300-320C).
Tip cleanliness, and proper solder and flux usage, are far more important.  Very often I see people who blast the joint with heat, but no heat transfer, and yet they wonder why their equipment is so terrible (tips crud up, oxidize and burn out).
Seven Transistor Labs, LLC
Offline VK5RC
« Reply #11 on: September 15, 2014, 04:21:08 am »
I use 350C, I suspect that you will get more thermal damage,  (I recall not only a maximum temperature but area under time - temp curve) especially if the thermal transfer rate of the iron is slow.  A hot iron with a quickly soldered joint,  with the flux also getting warm (and active) will produce a better joint. Too cool and soldering  the joint takes longer,  with the part getting hotter.
Soldering properly is both a science and art.
Offline Dago
    • Electronics blog about whatever I happen to build!
« Reply #12 on: September 15, 2014, 04:23:10 am »
I think my JBC came with a preset setting of 350C and I have literally never touched it. Works perfectly.
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
Offline Skimask
« Reply #13 on: September 15, 2014, 04:29:05 am »
600F for SMT pieces/parts.
650F for anything with any sort of thermal mass to it, or when doing re-work.
700F on really big parts, like those huge diodes, or big transformer lugs.
600F will melt solder on the big parts, but it'll take forever, and might not get all the solder melted.
700F will melt the solder on an 0805 resistor, right now...and could fry the little bugger as well.
It's not really the tip temperature that's making the difference.  It's more about the thermal mass of the iron and the part being worked on, and the ability of the iron to maintain a decent temperature to melt the solder and keep it melted on aforementioned part.
And I add about 25F-50F when messing with lead-free solder.
You use your equipment long enough, you'll get to know what works and what doesn't.
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline miguelvp
« Reply #14 on: September 15, 2014, 05:50:18 am »
I keep mine at 340C but it't a cheap Tenma so it's probably really lower than dialed.
I did measured the temperature a while back and it was reading low but not sure how low it is.
Edit: But I did change the tip and and upgraded the tip with an original Hakko 908-CK to convert it to a large mass iron.
https://www.eevblog.com/forum/beginners/diy-soldering-station-brand-name-soldering-iron/msg426688/#msg426688
« Last Edit: September 15, 2014, 05:54:30 am by miguelvp »
Offline andrewwong2000
« Reply #15 on: September 15, 2014, 06:17:27 am »
Interesting thread.. I've been using 270C for small stuff 0603 and 0805 and a bit higher 290 for larger components. Seems to work fine with my JBC.
Sent from my iPhone using Tapatalk
Offline David Hess
  • DavidH
« Reply #16 on: September 15, 2014, 06:58:02 am »
Even for surface mount I prefer using a larger tip than strictly necessary for more thermal mass.
I have done some lead free rework and it is annoying.  Even with a large tip for high thermal mass and conductivity, I often have to use a higher temperature which tends to scorch the board and lift the copper.  If I do enough, I will have to consider getting a better soldering iron.
The first thing I do is add some tin-lead solder the the lead-free joint to lower the melting point.  I have been thinking of picking up a spool of Sn40Pb60 or Ag03Pb97 solder for just this application.
Offline jay
  • Country: ee
  • Coder
« Reply #17 on: September 15, 2014, 07:51:40 am »
280-290 C is usually enough with JBC at work.. The sharpest tips need often 330C. I usually set my Ersa I-con pico at home to 320. There are situations when I've had to go to 350 to get enough heat.
SW engineer trying to design HW because it's more fun.
Offline P90
« Reply #18 on: September 15, 2014, 08:23:35 am »
it also varies between solder stations, I find some have faster recovery rate than others, not just thermal mass.
as already  mentioned, the best way is to get a feel for the way the solder flows...  :)
Offline DenzilPenberthy
« Reply #19 on: September 15, 2014, 10:17:14 am »
I'd say I go for something like:
(temps in deg C)
280 for delicate stuff like ICs
300-320 for general purpose stuff e.g. through hole resistors
350 for tinning wires, desoldering things, big chunky terminals etc.
For sensitive stuff I try and use the largest tip (greatest thermal mass) and lowest temperature that still allows you to get the joint done without too much hanging around.
I use a Pace ST50 station with a TD100 iron which allows you to change tips in an instant so you can use a different tip for each joint if you want to. Super useful!
I'd also note that for ceramic SMD capacitors I use a hotplate to bring them up to about 100 - 120 degC before soldering at about 250-260. Ceramic caps don't like thermal shock, it can make them crack.
Offline DanielS
« Reply #20 on: September 15, 2014, 11:17:43 am »
Guess I am more conservative than I thought - I usually run my iron at 250C for regular soldering and 300C for wicking.
Offline Lee697
« Reply #21 on: September 15, 2014, 12:00:09 pm »
I leave my Goot station at 350 deg C (660 deg F)....
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #22 on: September 15, 2014, 12:53:04 pm »
Soldering at lower temperatures is most effective with high thermal capacity and response units like JBC, Metcal, Icon, etc..  An example of mine below using a JBC wide blade at 260C.
Video here
« Last Edit: September 15, 2014, 02:05:56 pm by robrenz »
Offline KD0CAC John
« Reply #23 on: September 15, 2014, 01:36:00 pm »
Too many variables to say , even though lots of good info mentioned here .
One aspect that has not been mentioned yet is the conditions of the area / parts being soldered , at least as far as how clean or coatings or oxidized the surface is .
Sometimes having to add solder to the job to get things flowing - on rework .
On new or 1st time solder has been applied , is the board / component older - oxidized .
Having access to liquid flux can help a lot of situations , I never see anything right from the factory - some time between manufacture & by the time I work with it , so I use the liquid solder on the surface 1st and just before soldering .
Also when all the sudden it seems like the tinning stops , I will again use the liquid flux while the surface is still hot .
I have done radiator , plumbing and the 1st few generations of SMD and the same techniques seem to help ,
on large areas like radiators , I would use the heat to keep solder liquid then use a brush [ kept wet with liquid flux ] and drag the pool of solder down the jobs , this did the best soldering of large area and the fastest .
If you watch any of the NASA soldering videos , they do so much prep & cleaning , its painful to watch ;)
And like any work being down , it can take more skill to use cheap tools than it takes to use better tools .
I keep on the bench JBC and Metcal , and it does not have to cost more than mid-grade stuff , just some time shopping .
Like mentioned here I would rather have my tool on the hot side , to get the job done quicker and put less heat into the work .
Offline timb
    • timb.us
« Reply #24 on: September 15, 2014, 02:43:53 pm »
Generally I'll use Kester 63/37 when doing SMD work or soldering very thin wires. 63/37 is a eutectic blend, so it requires the least amount of heat to melt. I can use a temp of 225 to 250c and it melts instantly. It's also great for adding to lead-free joints during rework; this way you can reduce the heat to around 300c which helps prevent lifting traces or scorching the board.
Seriously, it's like some magic metal!
For normal stuff I use Kester 60/40 at around 300 to 350c, depending on what I'm doing.
(This is all with a Hakko FX-888. On my old Aoyue 937+ I'd add 25 to 50c to the above numbers.)
Another tip is to calibrate your iron, if capable!
Use the temperature probe that came with your multimeter, set the iron to 350c, firmly place the probe to the tip, wait 15 to 30 seconds for the probe to heat up and the iron to stabilize, then change the offset/displayed temp through your iron's calibration controls.
This way your readings will be accurate to the tip and not just the sensor placement.
Sent from my Smartphone
