Too many variables to say , even though lots of good info mentioned here .
One aspect that has not been mentioned yet is the conditions of the area / parts being soldered , at least as far as how clean or coatings or oxidized the surface is .
Sometimes having to add solder to the job to get things flowing - on rework .
On new or 1st time solder has been applied , is the board / component older - oxidized .
Having access to liquid flux can help a lot of situations , I never see anything right from the factory - some time between manufacture & by the time I work with it , so I use the liquid solder on the surface 1st and just before soldering .
Also when all the sudden it seems like the tinning stops , I will again use the liquid flux while the surface is still hot .
I have done radiator , plumbing and the 1st few generations of SMD and the same techniques seem to help ,
on large areas like radiators , I would use the heat to keep solder liquid then use a brush [ kept wet with liquid flux ] and drag the pool of solder down the jobs , this did the best soldering of large area and the fastest .
If you watch any of the NASA soldering videos , they do so much prep & cleaning , its painful to watch
And like any work being down , it can take more skill to use cheap tools than it takes to use better tools .
I keep on the bench JBC and Metcal , and it does not have to cost more than mid-grade stuff , just some time shopping .
Like mentioned here I would rather have my tool on the hot side , to get the job done quicker and put less heat into the work .
