Author Topic: What Solvent to Remove Silicone Conformal Coating?  (Read 8233 times)
Offline KDougTopic starter
« on: October 15, 2018, 09:24:35 pm »
Hi, I have made a repair to a circuit board on a power tool. I'm trying to remove the old silicone coating so I can apply a new coating. There are two different coatings, the first is a clear silicone, and the second is a potted type white silicone. Acetone has softened it up quite a bit and I was able to get the bulk off with a pick, but there is still a lot of little pieces left. What do y'all use? I'm new to this kind of stuff, any help would be appreciated.
Thanks
Offline vk6zgo
Re: What Solvent to Remove Silicone Conformal Coating?
« Reply #1 on: October 16, 2018, 12:51:46 am »
If you have a lot of little bits left, I'm doubtful about how useful a solvent will be.
You could try mineral turpentine----it doesn't dissolve anything, but penetrates into whatever gaps there are
& breaks the adhesive bond .
It is horribly messy & smelly, though.
Another possibility is baby oil, which seems to have similar characteristics.
It will lift, in an instant, wound dressings which seem to resist any other type of encouragement to come off.
Offline james_s
« Reply #2 on: October 16, 2018, 12:53:37 am »
Silicone is extremely inert, it's very difficult to find anything that will dissolve it. Your best bet is probably soften it with acetone since that seems to work then remove it via mechanical means. Seems easier to just remove it from the spot you need to repair and leave the rest alone.
« Reply #3 on: October 16, 2018, 02:24:40 am »
Thanks for the suggestions, I was more curious about some of the products that are designed for stripping conformal coatings.
Here's what I've found so far:
https://www.amazon.com/MG-Chemicals-Conformal-Coating-Stripper-Pen/dp/B077SXSJF1
(Not sure how well these pens work, but for one job it can't be that bad right?)
http://siliconesolutions.com/ss-sr.html
https://www.amazon.com/MG-Chemicals-Conformal-Coating-Stripper/dp/B01N5VI0KA
https://www.alliedelec.com/techspray-2510-p/70207178/
(Can be found cheaper)
Offline jpanhalt
« Reply #4 on: October 16, 2018, 05:49:08 am »
@KDoug
Only checked this one: http://siliconesolutions.com/ss-sr.html
Contains dodecylbenzenesulphonic acid.  Sulphonic (alternatively sulfonic) acids are strong acids (similar to sulfuric acid).   A hydrophobic side chain (dodecyl + benzene = C12+benzene) is added to facilitate penetration of the silicone.   Every effective remover for cured silicone I know of works on the same principle.   The sulfonic acid denatures the silicone and weakens its bond to whatever.
It works, but what will it to the electronics and FR4?
« Reply #5 on: October 16, 2018, 11:07:58 am »
@KDoug
Thanks for deciphering that, I was wondering if it was rated for electronics. I found the data sheets on two MG Chemicals products, let me know what you think about the ingredients.
https://www.mouser.com/ds/2/265/tds-8309-1154460.pdf
https://www.circuitspecialists.com/pdf/8310-liquid.pdf
Offline jpanhalt
« Reply #6 on: October 16, 2018, 11:24:04 am »
The first is just a mixed solved that includes acetone and di-ethers.  It does not denature or cause cured silicone to dissolve.  it does:
It also facilitates the removal of some thermoset coatings like
cross-linked silicones and polyurethanes by softening or swelling the coat to aid with mechanical removal.
I have used isopropyl alcohol in a hydrocarbon solvent (e.g., VM&P Naptha) to do the same.  Takes time and elbow grease, but it does help remove a thin film.   Probably will not work on bulk silicone.
The second includes slightly stronger organic ester solvents and "1-methyl-2-pyrrolidinone."   That latter chemical has interesting solvent properties.   It will dissolve/denature/soften cured enamels and is included in several "green" paint removers, including PeelAway.  Unlike  methylene chloride based paint removers, the enamel doesn't bubble up but rather becomes gummy and can be scrapped off relatively easily.   As I recall, it is also included in one of the developers for DuPont's dry resists. (https://en.wikipedia.org/wiki/N-Methyl-2-pyrrolidone )
Of the two choices, I woud try the second  with the 1-methyl-2-pyrrolidinone.
« Reply #7 on: October 18, 2018, 12:07:55 am »
Thanks for pointing out about the first option, looks like the second option was discontinued though. Looks like I'll just have to use acetone and a black light and be patient scraping it off. I just figured there was something easier than what I was doing. I'd rather not deal with the very harsh chemicals that some of you pointed out, but I do appreciate y'all  taking the time to comment.
