JIS standard screws, so you actually need a Pozidrive as the next alternative to the JIS screwdriver for them. No0 Pozi works well, though I often simply use a small flat screwdriver instead, as that is something that works perfectly on these. trick is getting a screwdriver with a parallel blade that is the width of the screw housing, or if it is not one slightly wider and grind it down slightly to make it a nice fit. I keep a screwdriver for those in my tool kit for networking, as those screws are common there for power on PCB assemblies. Coincidentally I also ground the profile of that screwdriver ( marked with some tenacious yellow tape on the shaft to identify it) to the right profile to handle Quante punch down block termination, as the correct Quante punchdown tool is both insanely expensive and also just as fiddly to use, and I only have to deal with them every so often so the screwdriver option works just as well. Started out as a Wera screwdriver and then had a trip to the grinder to get it right. Quante was a very short lived solution from the local telecoms monopoly, thankfully they only had it for around 2 years and I unfortunately had a lot installed, so have to deal with it. I prefer Krone punch down blocks, and have all the tooling for them as well as it is cheap, plus they are as reliable as those nasty Quante gel filled units. I do have one of the tap in test plugs though, just in case I need it on Quante, but the Krone I have the full set of insert and bridge blocks.
