Neither side of the loop is groundable/referenced to ground..
Its an expensive fan/heat exchanging ventilation controller that ventilates based on several presets which are fairly limited. I want to be able to emulate the controller eventually so a small computer with sensors can control it based on rules.
By and large I do want to have it running, most of the time, just sometimes less and sometimes more. certain things outdoors make me need to turn it off.
I have sinusitis- long story.
Generally I sleep better when there is a small amount of ventilation all the time. But currently it doesnt have all the settings I need.
Initially I dont want to change anything, I just want to see whats being sent so I can figure out which of the two devices is speaking when and what is being said, and why.
Eventually I want to be able to have a small SBC talk to the fan box in its own protocol if I can figure it out beyond a shadow of a doubt. I dont want to damage anything.
Does this sound like its potentially any known protocol? When there is no activity occurring (when the fan is off) this signal is sent once a second. Thats probably establishes the timing and when the controller wants the fan to do something it probably sends some variation back.
