Hello!
I recently "tore down" this transistor with HCl and heat. Two legs were lost in the process. Sadly it can't be repaired.
My question is this:
There are three parts: The back plate, the middle square that seems to have a boundary from the back plate, and the small off center square in the front.
Which part is the actual transistor? Just that little square on top? Or is the base the back plate, collector the middle plate, and the emitter the small square on top? (Guessing the smallest part is the emitter since it can handle the least amount of current and therefore heat.)
