Oscilloscope probe ground clips have their place on the bench,
usually in labelled plastic bags in a drawer, where all the alligators and crocs party on till needed.
DIFFERENTIAL OR DEAD is where it's at for me,
if the measurement or troubleshoot does not need a solid earth/ground/terra reference, it's ADD-INVERT Ch2 time!
Now I understand why, in that other thread, you were so vocal about needing four channels plus separate trigger input all the time!
If you are really serious about the above advice, and don't just mean to provoke, you are limiting yourself and the use of your scope quite severely. So, have you ever tried a "real" three or four channel measurement?
Ah yes, the ~DSO Defenders~, greetings y'all
My comments above are related to SAFETY i.e.
"Re: When does oscilloscope ground not work the same as DMM?" aimed at misfortunate people who try/attempt to use their oscilloscope probe and ground/earth croc lead like a floating 'Red/Black lead' multimeter in a typical 'new player' and 'old player' momentary brainfart
BANG! situation.
I prefer to go in to an -unknown fault scenario-
be it suspect voltages or plain curiosity waveform sniffing, with poor man's differential mode first, before setting up croc grounding and probe prodding.
Recommended if one is clueless or apathetic about DUT isolation, and types of isolation transformers (some which may or may not truly isolate)
You can save money too with an initial differential sniff, big money
(and no baby crocodile or alligator clip needs to die before their time, or have their tail fried) My diff work gets done with an analogue scope first, before I consider hooking up any DSO
And yes, I was safely performing 8 channel single ended? measurements with Tek cros fitted with dual 4 ch plugins back in the day and beyond,
before 'entry level' half@$$ed firmwareD 4 ch DSO snails came on the scene to spoil my expectations (and pocket)...
UPDATE: hoping that will change asap and I can retract some negatives.
Again, millions may disagree,
and free to exercise their choice to happy go lucky clip n prod away to their heart's delight
