Author Topic: When is it okay to use copper-clad aluminum (CCA) wire?  (Read 48405 times)
Offline SharpEars
Re: When is it okay to use copper-clad aluminum (CCA) wire?
« Reply #125 on: December 13, 2015, 02:40:43 pm »
I've seen some right s--tty bell-wire before now.  Its sometimes copper clad steel, and you find out when you b----r up your precision dykes cutting it!
You are lucky it wasn't https://en.wikipedia.org/wiki/Tinsel_wire which is truely the invention of the devil if you don't have the right crimps and tooling.
How did you identify it as CCA?    Take a short offcut of the bare strands, scrape them and boil in washing soda in a glass beaker or jar.  CCA will disintegrate, copper or copper clad steel will not.  Copper clad steel is most easily identified with a small magnet.
1. There is another simple physical method as well: Solid copper's cross section is purplish red. CCA's cross section is silvery.
2. Usage: 2a) High frequency (conductor skin effect) & low current leads, e.g. network cable; 2b) Neutral wire of 3-phase motors (far less current than in the other 3 live wires).
3. Refund is the best.
You guys are making this way to complicated. The easiest test for CCA is as follows:
Take stranded wire, strip it, hold it over a lighter. If the strands warp and ultimately melt, it's CCA. If they keep their form as they get red, orange and ultimately almost white hot, they're copper (or CCS, which you can test for with a magnet).
Aluminum's melting point: 660.3° C (You can easily melt it with a good adjustable soldering iron set to 700°+ C)
Copper's melting point: 1085° C
Steel's melting point: 1370° C (That's why you need to also do the magnet test)
« Last Edit: December 13, 2015, 02:44:46 pm by SharpEars »
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #126 on: December 13, 2015, 04:20:20 pm »
It NEVER  is okay. Don't buy and/or use the cheap shit.
Offline Monkeh
« Reply #127 on: December 13, 2015, 04:23:45 pm »
 :palm:
« Reply #128 on: December 13, 2015, 04:28:28 pm »
When you are making 10 000 cheap microwave ovens a week and want to reduce the mass of the transformer by 1kg and the cost by $10.
Offline Yansi
« Reply #129 on: December 13, 2015, 04:36:13 pm »
 But is the OP manufacturing a 1 000 000 series of microwave transformers?  ;D
Still its not an excuse to use cheap rubbish. The price difference is too low for the difference in durability, quality and reliability.
« Last Edit: December 13, 2015, 04:38:10 pm by Yansi »
Offline SharpEars
« Reply #130 on: December 13, 2015, 04:39:02 pm »
Don't give Som Tin Wong any ideas - oops, too late!
Offline SharpEars
« Reply #131 on: December 13, 2015, 04:39:54 pm »
It is OK when you are a sucker buying on eBay too clueless to know what CCA is. Duh, I can use it with ma' truck's battereh to get mo' of dem Col' Crankin' Amps (CCA)!1!!11!1!
« Last Edit: December 13, 2015, 04:41:46 pm by SharpEars »
Offline Monkeh
« Reply #132 on: December 13, 2015, 04:41:22 pm »
Large transformers already use aluminium windings, and they have for a long, long time. This includes expensive, Western manufactured units. Why? ... because in some applications, the cost and weight difference makes it the better material.
Aluminium is used for busbars and wiring in many situations as well, where again, the cost and weight savings make it a better choice.
None of this is copper clad, though.
Offline SharpEars
« Reply #133 on: December 13, 2015, 04:42:53 pm »
Certainly for very low gauge (i.e., large diameter/volume) cable/bus bars where weight is most definitely a factor, this makes total sense. It also makes sense for heatsinks. For 18 AWG stranded wire, though... I think I'll pass...
Online Ian.M
« Reply #134 on: December 13, 2015, 04:43:27 pm »
The power companies love it for overhead lines.  Its got a better conductivity to weight ratio than copper, doesn't cause bimetallic corrosion of the high-tensile steel core and is *FAR* cheaper.   Other uses where mass or moment of inertia isn't important, its far less appropriate and small diameters or worse stranded, are only for sell-your-sister crooked cheese-parers!  :box:
Offline Electro Fan
« Reply #135 on: December 13, 2015, 06:29:45 pm »
Offline Yansi
« Reply #136 on: December 13, 2015, 07:31:33 pm »
I'd rather spend some money for a proper wire from reputable manufacturer. CYA or LiFY (veeery nice) type one.
I am just not bothered using the cheap rubbish wires.
Offline Jay112Topic starter
« Reply #137 on: December 20, 2015, 09:40:34 pm »
I wanted to thank everyone for the help. I just received confirmation that the seller sent a full refund to my credit card.
