As Blueskull says, they are a current mirror, and all are identical. In the LM358 given as an example all the positive current sources are supplied from a single diode connected top transistor, with the various currents being provided by making the current mirror transistors with different areas, so that the current ratios are all going to be very close. Thus the 4uA has an area of 2, the 6uA an area of 3, and the 100uA an area of 50 times the area of the diode connected transistor.
The current source is provided with startup current and bias with a jfet connected in pinch off, so that it gives a small well defined current. Smaller than a chip resistor of the same value by a large amount. The pull down is often implemented just by using a slightly larger jfet as a constant current sink, not too precise but will stay in the ballpark over operating range quite well.
