I gave up on VFDs years ago, I like the colours of the phosphors, viewing angle is good, available in numeric, alpha numeric, dot matrix, bar graph and custom formats, they're still used on point of sale terminals and on cash registers. They're relatively easy to manufacture, print the electrodes then the phosphor, align grids and heater supports then frit seal maybe and vacuum pump. Something like that. It's all glass, metal, phosphor, cathodes and vacuum. Custon CRT in other words, same technology except scanning mechanism is different, it's fixed.
The down side is the short life of the phosphor and also cathode emission. You have to run the cathodes relatively cool compared to a standard vaccuum tube so maybe cathode coatings "boiling off" or something like that, you would have to ask the people that design this sort of stuff. Field emission electrodes were researched but never happened. Also, there is a diminishing amout of plant to manufacture glass vacuum tube technology.
Seems like Toshiba still putting VFDs into their tills but other manufactures use LCD now.
