Author Topic: Where to find ESP8266 firmware?  (Read 508 times)
Offline Gabriel
« on: December 03, 2017, 12:06:09 pm »
Hi All,
I have recently acquired some ESP8266 modules. I have since had a search around for the newest firmware. I have found so many versions on so many websites that I am slightly lost which is official or not and what works with the Arduino IDE. I have got the board definitions from http://arduino.esp8266.com/stable/package_esp8266com_index.json this seemed to be the most recommended one. Which firmware do you guys use? I there an update for this module? AT+GMR gives me
AT+GMR
AT version:0.21.0.0
SDK version:0.9.5
OK
Sorry for being a noob,
Gabriel
Offline Jwillis
Re: Where to find ESP8266 firmware?
« Reply #1 on: December 03, 2017, 02:01:10 pm »
Not familiar with arduino stuff but I did find this if it helps http://espressif.com/en/products/hardware/esp8266ex/resources
Offline danadak
« Reply #2 on: December 03, 2017, 10:38:51 pm »
Usually the board vendor has a link for the firmware.
FLASHER is one utility that will do it - http://www.instructables.com/id/Intro-Esp-8266-firmware-update/
Regards, Dana.
The following users thanked this post: Cliff Matthews, Gabriel
Offline Gabriel
« Reply #3 on: December 04, 2017, 07:26:10 pm »
Thank you very much! I will try the links in the instructables.
Kind Regards,
Gabriel
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #4 on: December 04, 2017, 08:06:43 pm »
Hello Gabriel,
what way do you want to go with the ESP? If you want to run LUA script or go by AT commands, then the instructables link hooks you up I guess.
My recommendation however is to write your own firmware via Arduino IDE. The integration of ESP8266 support is straight forward, just follow the instructions on the ESP8266 Arduino github and the board manager will take care of the rest.
Everything else works just with any other Arduino compatible MCU.
He’s like a trained ape. Without the training.
