Go directly to the manufacturer's application notes. Even G0HZU can't argue with them.
Why don't you practise what you preach?
Maybe if you read the manufacturer's application notes and analysed the circuit below then you wouldn't find yourself posting up a circuit that doesn't work as you claim
The arrowed resistor is 0.1R.
This resistor is a key part of the PSU design. It's value depends on the max design current for the PSU, the max design current of the linear regulator and the current gain of the pass transistors and the Vbe drop. There is a simple design equation for this.
It isn't going to work as a 10A PSU if you fit a 0.1R resistor here. Your circuit below is WRONG.
It doesn't work as a 10A PSU. It will presumably work up to the limit of the LM7812 which will be typically much less than 2A. Also, once the 0.1R resistor value is corrected, the 470uF cap next to this resistor is about a thousand times bigger than it should be and this will screw up the response time of the feedback loop. This will cause all manner of voltage spikes on the output.
Even if you fix both of these issues the circuit is still crap. The spread in current gain of the pass transistors, the lack of overvoltage protection, the lack of soft starting mean that this PSU is a disaster for a beginner to build.
It isn't a 'modern' design either. The application note these designs are based on in the Fairchild datasheet dates back many, many years.
