Hi guys,
I am trying to repair a used laptop I've just bought with a motherboard that refuses to power on.
I've installed a new mSATA SSD, installed Windows normally and after a few reboots and a power off
the laptop never turned on again.
No burnt fuses on the motherboard, power comes in normally and everything I've checked turned out
to be working fine except the following. Two of the 5V MOSFETS driven from the peak current mode
power controller look like they have a short.
Below is the circuit that has the short:
MOSFETs Q89 & Q90 have a direct short between drain and source. I have removed all power and CMOS
battery, have discharged the gates and the short is still there.
Capacitors C601 & RFC30 are shorted as well.
My question is which component do you think its more likely to create the short?
One of the capacitors or one of the MOSFETs?
I don't want to start removing components randomly, especially these tiny capacitors.
Is there any other test I can perform to isolate the faulty component?
Thanks!
p.s. The full schematic of the power controller:
https://postimg.org/image/t3nv3wycj/
