Author Topic: which IC for audio switching  (Read 204 times)
Offline brownt
« on: January 19, 2019, 01:58:40 pm »
I would like to make a guitar signal level, audio switching circuit. I was thinking a 4066 or 4053, but I don't know how these might degrade the signal. Are they ok, or are there some specifically designed ICs that are better. thanks
Offline xavier60
Re: which IC for audio switching
« Reply #1 on: January 19, 2019, 02:34:07 pm »
Wow, I have just told someone else the same thing.  :)
CMOS analog switches have non-linear resistance with signal swing. To minimize distortion, they have to be lightly loaded. Also keep the signal swing well within the bounds of the supply rail voltages.
This looks useful, http://www.geofex.com/Article_Folders/cd4053/cd4053.htm
« Last Edit: January 19, 2019, 02:36:27 pm by xavier60 »
Hioki AS100D vom, HP 54645A dso, Fluke 87V dmm, AN8008 dmm, Agilent U8002A psu, New! FY6600 function gen.
The following users thanked this post: brownt
Online Richard Crowley
  • KE7GKP
« Reply #2 on: January 19, 2019, 02:37:48 pm »
4066 has been seen in some rather high-end audio gear.
When applied properly (powering, biasing, loading, etc.)
I thought this was interesting:
http://www.thetonegod.com/tech/switches/switches.html
Offline John B
« Reply #3 on: January 19, 2019, 02:39:21 pm »
Is it a battery based application? A small signal mechanical relay may provide the most performance for an audio application. Ie, low resistance, no non-linearities, isolated signal and control circuits. In mains powered stuff it's the way to go.
