ATX can be moded to wonderful things, however mains voltage is dangerous and slight mistake could send the supply into a explosion (especially if you wind the output voltage too much and dont replace caps on the output)
Go for linear, they are simple, well documented, easy to troubleshoot and repair, stable, they are made from ready available parts... list goes on...
