Try this:
Attached .doc
The problem with that is it involves a DC path for the current to flow though, which will cause electrolytic action and corrosion.
Use AC, rather than DC, that way there is no net flow of ions and less corrosion.
Comments accepted, but with this elaboration: (added to doc)
Due to resistor values, current will be uA
Any corrosion will not affect circuit operation as the salts/oxides conduct.
Only 1 probe is constantly immersed.
Probes can be sourced as Stainless welding wire and therefore cheap if replacement needed.
Sensing circuit is very cheap to build, I suggest you rats nest it for a trial and evaluation.
