Hi All,
Long time fan of the eevblog, i have been reading the forum for a while, while a lot of the answers here goes a lot over my head i thought i would like to ask the hivemind for a question that has been bugging me for a while.
i have a saltwater aquarium and want to measure the water level of the aquarium, theres a lot of water levels that i would like to measure:
the main tank.
the overflow chamber.
the sump.
the return champer of the sump.
i have a aquarium computer set up to alarm me when something goes wrong, right now the alarm points are:
temperature
ph
light level
and a bad solution to salinity.
right now im looking into getting data on the water levels, mostly for statistics and alarming, but also for automating water changes.
i have tried the following sensors:
ultra sonic sensors, they corrode in the salt environment within a month.
float sensors, algae and animals love ´em, they sit on them making them not trig when they should, and they make bad sensors for statistic data, they only trig when the water level goes up to it, or down below it.
ir sensors tcrt5000L, i haven't been able to make this work reliably, the return fluctuates a lot and the range is very limited.
i have been thinking about using the Etape sensor, but it will cost me around 50 dollars shipped per sensor, and i would need 4 of them(and its pretty ugly to have in the main tank)
do any of you have an idea of what sensor i could use, preferably one that could measure the water level from above the water.
Thanks for the help!
Michael
