I have yet to find a datasheet that says "if you don't clean this flux, here be demons!"
97SC HYDRO-X 2% .064DIA/16SWG Lead Free Water Soluble Wire Solder Sn96.5Ag3.0Cu0.5 (96.5/3/0.5) 14 AWG, 16 SWG Spool, 454g (1 lb)
https://www.digikey.com/product-detail/en/multicore/732977/82-135-ND/2498933Stranded wire should not be used. Strip any insulation back so that flux residues are not trapped during the washing process.
CLEANING
It is essential that the residues from soldering with Multicore Hydro-X cored solder wires be removed as soon as possible after soldering.
The residues from Multicore Hydro-X cored solder wires may be readily cleaned in conventional equipment using water. It is important that the
cleanliness of boards and components is thoroughly checked after soldering and cleaning. The usual procedure is to continuously check the co
nductivity of the final rinse water as a measure of ionic contamination. Samples of cleaned boards should be subjected to a laboratory corrosion test, insulation
resistance test, or ionic contamination assessment.
should be enough warnings and precautions for you.
