Author Topic: Which solder paste syringe for Metcal DX-250 applicator?  (Read 1944 times)
Offline andersjmTopic starter
« on: October 23, 2016, 07:42:17 pm »
Hello forum,
I've been doing a few boards, and after soldering using regular solder wire and a soldering iron, a year ago I switched to solder paste and hot air gun.
I've had good results, but for larger boards my hands get really tired after a while when applying solder paste from a syringe, manually.
So now I've purchased a Metcal DX-250 (and a SIL-AIR 15/D compressor). I know maybe I should go with stencil instead, but that seemed messy to me. Anyway, now that I've already purchased the DX-250 I'm certainly going to use it at least once so please bear with me!
The Metcal came with a syringe, that I could probably fill with solder paste and use.
However, it would be very much nicer if it were possible to buy solder paste already in a syringe, and have that syringe somehow be usable with my Metcal DX-250 without needing to any messy mixing/scooping.
Anyone got any ideas?
I can't seem to find a specification for the syringe that was included with the Metcal. I've attached a picture.
Are there industry standards for solder paste syringes? Which model is the one I got from Metcal?
Offline Signal32
Re: Which solder paste syringe for Metcal DX-250 applicator?
« Reply #1 on: October 23, 2016, 09:27:47 pm »
Looks suspiciously similar to http://www.aliexpress.com/item/-/32367711078.html
I'm not sure if there's a standard though, perhaps someone else can confirm.
I have that syringe, so you can post here the dimensions and I can check for you.
Also the DigiKey listings seem to be in the same container: www.goo.gl/9WYOQp
The following users thanked this post: andersjm
« Reply #2 on: October 23, 2016, 09:32:46 pm »
The critical dimension seems to me to be the inner diameter of the syringe tube.
Mine is approximately 15.7mm.
Offline Signal32
« Reply #3 on: October 23, 2016, 09:43:16 pm »
For mine inner diameter measured at 15.6. Outer small diameter 22.3. Outer large 34.5 mm.
Sounds like it would be standard.
Offline zapta
« Reply #4 on: October 23, 2016, 10:00:47 pm »
Determine the standard size 10ml, etc and you should be good.
« Reply #5 on: October 24, 2016, 05:43:32 am »
Thanks a lot for the help!
It seems that there's in fact a defacto standard for 10cc syringes. Excellent!
I suppose since all 10cc syringes fit, there's no need to specify a syringe type in the datasheet. Still, it would have been nice if the industry had given a name to the syringes, like "TYPE A 10cc paste syringe" or something, and had that specified both on the prepackaged syringes and the applicator stations  :)
