I did buy these cheap tweezers but to be honest have never used them much. http://www.ebay.com.au/itm/Tweezers-Capacitance-Resistance-Diode-Test-Tester-Pen-Multimeter-Meter-R-C-SMD-/161595625720?epid=1037823615&hash=item259fd990f8:g:PUIAAMXQdGJRzV8S
Of course the ones you have look a hell of a lot better obviously
My ST3's are now updated to ST5, of which there are couple of models and I'd like to upgrade to their top model.
Even my old ones do an ESR measurement which I find extremely useful when checking electrolytics as you get the uF and ESR in the same window with a single measurement.
A couple years back I grabbed a set of Mastech tweezers, IIRC #8910, I think they are better spec'ed than those you linked but nevertheless they didn't cut it against ST3 so I gave them away.
I looked hard at SMD and made the plunge a decade ago, worried as hell if I'd manage it but with a visor magnifier it was easy, so much so that I haven't made an
all TH PCB since.
Soldering these wee components onto PCB is just the start ( if you
can solder), you have to see the little blighters and hold them on point while doing so. We each have our favoured methodology, mine's been KISS and develop the skills with practice. I
never use solder wick as I can't bear to fork out what most robbers want for the stuff instead persevere with a manual sucker that can get everything as clean as I need it if you know how to use it. Flux is another one, until very recently never used, just rely on enough being in the flux cored solder that I use of which could be anything I have around that suits the job, The only roll I know what it is, is some I bought nearly 20 years ago, a low temp silver bearing type that is now saved for special needs.
