Contrary to popular belief, the principal issue with "free energy" is nothing to do with science and engineering, and everything to do with Economics. In fact, the concept of "free" in monetary terms simply does not exist. IE everything you do has a cost, even if that is sitting in front of the telly (because you could be using that same time to actively earn money, and hence, sitting doing nothing is "costing" you, and hence not free!)
So, even if you make a system that can somehow capture energy, even if you make it from parts you found in a dumpster (i'm think of you here Dave ;-) then it has cost you time. Time which you could have used to earn some money to simply buy that energy from another source. So, the real crux of the matter becomes the ratio of cost to reward, no matter if that cost is actual money or your time. Hence, these so called "free energy" systems that seem to harvest tiny amounts of power, are actually nothing like free.
In fact, they make Grid power, generated by electricity companies look incredibly good value. I mean, here in the UK, i can buy a kWHr of electricity for something like £0.12.
Imagine trying to generate that yourself? Here's an example:
On my bike at can manage to output around 150W continuously, but it's extremely hard work. To generate 1kWhr, i'd have to sit on my bike (with a alternator attached) and even at some mythical 100% efficiency, pedal like mad for 6hrs 39 min to generate that! And let me tell you, NO WAY would i do that for just 12pence........ ;-)
