The reason why common usage swapped over to center positive is NOT the battery switching. There is *NOTHING* to stop you switching the negative side of the battery using the sleeve shunt of a center positive power jack.
If, however you have a PSU with a three pin grounded mains plug, and the output is grounded, then putting 0V/Ground on the center contact with the outside 'hot' at whatever the DC output voltage is would be F&*%ing *STUPID* - the first time its sleeve touches another ground (e.g. a grounded case), it would short out the PSU.
As unwanted ground loops are a major problem for music kit, you pretty much never see a grounded PSU for an effects box or pedal so there has been no good reason to change over to center positive, and the vast number of center negative devices out there are an excellent reason *NOT* to change over.
