3 is the regular commercial spec device, with a rating from typically -40C to 70C operating temperature. 2 is the industrial rating, normally tested to a closer tolerance, and rated for typically -40 to 110C, and costing about 3 times the price typically per part and generally with a restricted range of package styles. 1 is the military/aerospace rated part. 100% tested for both functionality and tested for a long period typically 6 months at elevated temp to weed out the marginal devices. Rated from -55 to 125C and normally only available in a sealed hermetic glass sealed can or a ceramic package. Very restricted package styles, and typically 1000 times the cost of the commercial spec because of the long test times and each one having a serial number or lot number with a certificate of conformance associated with it.
