You seem convinced that Apple should be DIYing its PSUs. But have you actually thought about why they farm this out?
That's the question posed in the initial post. If I *knew* why they did, I wouldn't have asked.
Your initial post asks in general, I was addressing that you seemed to single out Apple. But my main point was that you're asking yourself "why don't they?", and I'm suggesting you ponder "why do they?".
A) They've been buying PSUs from outside vendors since at least the mid-late 1980s. Though I guess there might be some exceptions, these are generally custom parts made for Apple. If this wasn't advantageous, it's unlikely they'd continue doing it.
No one is infallible. I can question Apple's refusal to add touch-screen support to OSX, or question Nintendo's decision to not put their entire vintage game library for sale on Android and iOS. I don't have to be all-knowing to question a decision.
I simply take issue with your tone throughout this thread, which has been that it obviously makes sense to do it in-house. Your choice of words ("infallible"!) is again implying that you think they are making a mistake.
B) Whether a third party makes the PSU or not has nothing to do with why it's a separate module. Safety and replaceability immediately come to mind as reasons why you'd want it separate. (In the past, having separate PSUs for different line voltages was also a factor, but that's pretty much vanished thanks to modern wide-input-voltage SMPSes.) If there were some huge advantage in integrating the PSU into the same boards as the logic, then they'd do it. As I understand it, PSUs can get away with far cheaper PCBs than most other modern electronics; if you can build a part of your product on a single-sided PCB that costs a fraction of the 4-layer (or more!) board needed by the rest of the electronics, wouldn't you want to do this? Remember that PSUs are often very physically large compared to the circuits they're powering. So you'd be needlessly increasing the area of costly multilayer PCBs by a huge percentage.
That's a good point, I didn't consider that one. However this does assume we're talking about a high-power PSU, and the Apple TV's current PSU is under 12W (12V/0.917A), which doesn't require unusually thick or wide traces. Still a good point about having the PSU on a separate board, though.
The power rating of a SMPS is totally irrelevant to the issue of requiring separation. You have up to 250VAC (when nominal 230V is on the high side) coming into the SMPS. Whether you need 5W or 500W of output, you don't want a fault to result in mains voltage showing up where it's not supposed to, like a USB port. Or were you addressing a point other than safety? Cuz my point about single-layer PCBs being far cheaper than multilayer ones is a fact regardless of the power of the PSU.
C) Apple is a truly gifted systems integrator. While Apple does a lot of engineering, its suppliers do a ton of it as well, designing modules to Apple's needs. Apple's magic sauce is the software and the choice of components that work well together, though increasingly with custom-designed components as needed.
D) Name one single part in an Apple device that is actually manufactured by Apple. Oh right, they contract manufacture everything now. Since every single module inside an Apple product will be outsourced anyway, why not let PSU specialists do the PSU designs to Apple specs? They do this for the custom CPUs in iOS devices, among many, many, many, many other custom components.
Components, not entire PCBs. They do almost all PCB design and assembly internally. The only notable exceptions are things like USB power bricks which they buy off-the-shelf in high volume.
Nonsense. I said "modules" and "components" for a reason. Apple does its design in-house and then farms out 100% of manufacturing and assembly. (Save for a tiny bit of in-house final assembly for US government contracts that require it to be "made" in USA.) Every single part that goes into an Apple product was manufactured by a contract manufacturer, subcontractor, or specialty supplier. From the PCBs, to modules like vibrator motors, camera modules, screen assemblies, … the list literally goes on and on, encompassing 100% of the BOM.
Apple doesn't own factories making iPhones or computers; Foxconn, Quanta, Pegatron, etc. do.
The USB power bricks
aren't off-the-shelf, they're custom-made to Apple specifications. You only
think they're off-the-shelf because the entire clone accessory industry shamelessly copies Apple's designs (well, the exteriors, that is; the insides are woefully deficient) to the point that you see them everywhere.
E) You mention appearances; who cares who manufactured the PSU when it's hidden inside the housing anyway? Look at the Apple power supply innards you yourself showed: I think that by most standards, they show an astounding attention to aesthetics, considering that end users will never even see them.
I think you countered your own point there...
A) "who cares what they look like if the end user will never see it"
B) "they show an astounding attention to aesthetics, considering that end users will never even see them"
So when you ask "who cares what an internal part looks like", your answer is "Apple", and I agree. They seem to care what everything looks like, regardless of whether it's internal or external. Why make your PCB matte black if glossy green is more easy to repair/debug? Because it looks better. It looks futuristic and cool.
It wasn't my point I was countering. I only addressed appearance because you said:
It's just inelegant, which as a company obsessed with appearances, you'd expect Apple to be bothered by. They develop their own SoCs, but they stop at the PSU?
In other words, you claimed they didn't pay attention to the appearance of the PSUs, despite your original post showing what can only be described as a lavishly designed interior.
Apple has often said that their biggest strength is saying no: Saying no to products Apple could make, but where they wouldn't be significantly better than anyone else. I guess they concluded that they won't be better at making PSUs than the PSU specialists, so there's no point in them doing it.
And I'm not saying they're wrong, I'm merely trying to understand their reasoning.
We will never
know, since Apple doesn't generally explain its reasoning publicly. We can only attempt to infer what their reasoning is, and debate sensible arguments from people like folks here.
But it's possible that the actual reasons are different from the ones we all conclude!
